Hey, so I’m a 15 year old who loves my go kart. Today I let my brother drive it and he crashed the right wheel into a tree… it bent the axle. It’s about 4.1/2 inches long. Is there a way I could bend it back or do I need to buy a new one. It also bent what looks like the steering linkage but I plan on bending it back with a hammer.
Can it be fixed? Certainly.
A lot can be fixed with a vice, a hammer, and some heat.
The teaching process to do this probably isn't an online course.
So your best option is like has been said - ordering new spindles. Since there are many variations of these,
the better measurements you can give the vendor from your undamaged one increases the likelyhood of
getting the correct replacements - one of these measurements being the camber angle the "axle" (bolt LOL)
is welded onto the spindle. Even if you replace these in pairs, it would be better that the new ones are at
least close to the old ones. Same with the tie rod attachment arms - there are differences there, too.
As to tie rods/ends - common "wear items" that are often damaged. If you plan on carting - learn how to
make your own. I buy tie rod ends in bulk for my lawn mower repairs and make replacement tie rods with
round stock. Much cheaper than store bought ones. Either weld a bolt with the correct thread size/pitch to
the proper length round stock, or tap the stock with the correct thread count/pitch. Repeat as necessary.
Good luck with your repairs. Enjoy the kart.
