Bent axle 1 1/4 " solid aluminum 45"
Bought a used buggy similar to YD 3203. When starting to disassemble the rear live axle to put a new spocket on I realized the axle was bent. The driver side tire seems to rotate true, but there is a noticeable wobble on the passenger side wheel. I found what looks to be the exact same axle I have on BMIKarts website.
1 1/4 " diam. Solid Aluminum 45" long 1/4" opposing keyways. $45
I figured I might replace axle (and bearings) since its bent....
Is this axle sufficient for a near 300lb kart??? ( since its bent, I'm not sure)
Or what kind of axle would be more appropriate?
Aluminum? I'd go with a steel one personally.
Thanks. Perhaps that's why it bent.
---------- Post added at 07:35 PM ---------- Previous post was at 07:21 PM ----------
I found a 44" steel tubular axle 1 1/4" OD and 1/4" wall thickness.
Will the hollow steel be better than solid Aluminum or should I keep looking for a 1 1/4" solid steel axle??
Thanks again
Being a buggy, it's designed for off road use so, a more heavy duty axle is required; aluminium is lighter & stronger than steel depending on the application & this application is no bueno...
Likewise, a hollow axle will, eventually, do the same as the ali axle...
Keep looking for a solid 1 1/4" steel axle...
Apparently not so easy to find at around 45". Thinking of having a keyway cut in 1.25 " solid A36 hot rolled mild steel roundbar
https://www.metalsdepot.com/products/hrsteel2.phtml?page=round
4ft $25 shipping $15, then find someone to cut keyway
Will this type of steel work??? Haven't been able to locate 44-45" solid steel 1.25 " dia axle with precut keyway. Don't plan on doing much off roading but don't want another bent axle either
Thanks
Although it may be more expensive, 1045 TGP Precision Steel is much better for an axle...
The main issues with A36 are:
- it's a little softer
- size is not 100% accurate
- it has a scale finish which, once removed, may leave the axle undersize...
The insulting part is, regardless of the cost of the steel, it's the price of machining that will really bite you...
BMI used to supply custom axles; maybe give them a call or shoot them an email...
After doing some research, that's what I picked out too. I got a couple tin knocker friends I'll beg for help
Do you need threaded ends?
This site has quite a few axles--> http://gokartgalaxy.com/axles.htm
No I don't need threaded ends.
I'll look and see what's available thanks
---------- Post added at 11:59 AM ---------- Previous post was at 11:49 AM ----------
I purchased the stock round bar. 48" long 1.25" dia 1045 steel
Turned, ground, and polished to +/- 0.001"
I've started contacting my friends, local machine shops, and machinists on Craigslist.
All I need is it cut to length (45") and put two keyways (maybe 21.5") on each side, right????
I don't need threads or snap ring groove (I don't think). Is there anything else I should be asking for when getting estimates???
I asked like so...
Have a 48" long 1.25" dia solid 1045 steel round bar. It's preturned, ground, and polished to +/- 0.001".
Need to make it into a 45" Gokart axle. So need it cut to 45" and need a 1/4" wide by 1/8" deep keyway cut into it.
It can be 1 continuous 45" keyway
Or
2 separate opposing keyways each about 21.5" long
Thanks again, everyone in the karting world is so helpful
machinist@large
West Michigan, 49331
McMaster Carr p/n 1497K403, 48" long full length key. $85.00 plus shipping.
There's your price comparison. If someone bills you at shop rate, this is about as cheap as you'll get it . If your friends are willing to cut you a break, good for you.
:ack2:
That is fantastic. Craigslist guys want $75 bucks an hour
crazykart
Crazy member
Swartz Creek, Michigan
Hmm, I have a thought, might want to research a bit though on your own. Something that's crossed my mind before
Taking one of those tubular axles, and then getting a piece of high grade steel to tightly slide inside the middle of it.
My thought on it before was for weight reduction: tubular aluminum axle with a tight fitting piece of steel down the middle for added strength. Plus tubular axles are cheap, and the steel is cheap enough.
Anyways, tired thought and my .02 dong.
I like this idea!!! However I already ordered The un-keyed solid steel and then cancelled and ordered the soild steel keyed shaft. 15 lbs difference will be about 3 percent of total kart plus rider weight. As for spinning the axle, not sure how the axle's moment of inertia" (yea Physics class) change affects performance. Assuming it will hurt low end more so than top end but probably will hurt both. The current design has each rear wheel sticking 10-12" outside the bearing. Also maybe by the axle bent.
Anybody know how stability / handling might be effected on buggy (mostly used for pavement, no crazy hills) if I were to shorten the rear axle by 6-12", leaving the the distance between the front tires unaltered.
Something like 45" wide in front and 36" wide in the back
---------- Post added at 09:22 AM ---------- Previous post was at 09:11 AM ----------
I was originally not concerned about low end, because I thought the torque converter, 6:1 sprocket ratio, and 16" tires should be alright. I thought most buggies this size had 20" tires. Anyway we shall, unfortunately I won't be able to compare cause I never ran this with the old axle
Not a bad thought but, not exactly a good thought either...
A 1 1/4" steel axle will still be stronger than what you proposed; the hollow axle would be hardened, whereas, the insert would, most likely, not be, so, at best, it would only act as a mild buffer; given the dimensions of the hollow axle, my guess is the insert would be ~3/4" which, in the grand sceme of things, isn't that strong; remember, in this scenario, the strength is added together, not multiplied as is the case with larger dimension material...
With a heavier axle, the total rotating mass will increase, meaning, it will require more energy to move it...
What does that mean? Initial acceleration will suffer... & acceleration in general but, once you have the momentum moving, it should push along nicely...
The downside is, with the added rotating mass, it will require more energy to stop as well...
Keep in mind, we're talking single digit pounds, not tons; an extra 5lbs of rotating mass on a 300lb kart is minimal at best...
Stability may be reduced slightly, handling/steering should improve
That should be ok; worst case, you may need to hunt down a smaller J/S sprocket...
Thanks for taking the time to be so informative and thorough
Well that was fast delivery!!! Thanks for the suggestion. 48"X 1.25" 1045 fully keyed shaft. $99 delivered to my door. Didn't get the GTP fully keyed 1045 (which they do offer for xtra $45 or so) but I feel this should be fine. Now waiting for my bearings and flangettes which didn't like my method of removing the old bent axle
