Hey guys. I recently purchased an older go kart.
From the start, when you pressed the gas just a little the kart would not move, and then a little more and it would jerk forward.
Now, after having to clean out carb due to water, the kart will only jerk periodically, but will not actually move. (Unless downhill)
My first thought was that the belt is too loose. Upon inspecting the belt, there is about a 1 inch section where the belt is warped, like it was getting melted or rubbed. Also, I was able to take the belt off without taking anything loose.
I have little knowledge of torque converters so was unsure of whether it is supposed to be that loose. I know that they cannot be too tight. So, is it just the belt or do I have a bigger problem?
Manco 485B-2 TracerLXT Kart.
