Belt issues
branandlee
kartnewb
Central Ohio
I have a Manco Fox Vortex gokart. I just bought it off the kid and he handed me a spacer for the torque converter and said he forgot to put it on. (I should have walked away then.)
Needless to say, I have tried several different spacing combinations and am still having issues. The belt on the torque converter does not grab at all. I also think that they are not lined up straight enough which is probably causing more of my issues.
I have attached a few pics and will gladly get more if it will result in help. Feel free to point out any other issues you see as I'm still a newb getting started.
Thanks in advance.
tinamcjittles
ello m8
Allovau
It's definitely out of line, it doesn't grab when you give it throttle? It isn't supposed to grab when the engine is off.. That being said it looks loose on the bottom of the first picture, and is there any way you can fix the alignment?? Like removing/adding washers?
Bbqjoe
Banned
Location, Location
It might be better to remove the belt for judging.
But I'd say you're a washer or two short behind the driven.
But in pic two, something looks wonky.
Bbqjoe
Banned
Location, Location
I keep looking at the second pic. Something appears off.
Is that crack in the engine mount affecting the torque converter any?
First:
you must replace the spring in your driven unit..
that blue one is too short and not weak for a series 30 TC!
you need a red one
(if that's the one I think it is... anyway it needs to be replaced since that's causing the driven sheaves to be spread apart)
Be sure to preload it properly whwen you do or the correct spring won't work either ;)
once that's done you should add another spacer to the driver to have the belt run as straight as humanly possible;
and as long as the driver still has it's weights working.. the TC itself will work flawlessly ;)
PS while you're at it taking it all apart to replace the spring, do a full maintenance too;
the TC it'll reward you with smoother shifts and longer life
branandlee
kartnewb
Central Ohio
So I got some garage time this weekend. Took it all off and started new. There are not any of the original washers or spacers that should have come with the TC apparently. Or at least none matching the above video.
I also figured out that the bronze sleeve is missing from the driver and the spring in the driven is the wrong one. So I ordered both of those and am waiting on that. I did fire it up and try running it up the road. It was better but still. It right. It seems like the belt is too loose. And possibly the chain is still hitting a washer or spacer.
Joe-405
Enjoying New Projects
U.S.A.
The spring you have on there now is not reverse driven so the driven will not properly catch the belt so you got to wait until that spring shows up
KartFab
Dallas, TX
2 is the best 'feeling', and 1 and 3 arent that great. I tried em all.
With one way, you get like just the same torque at start (just like any other setting), and it immediately goes to high gear, which your engine struggles to ramp up its rpms (kinda like starting a stick shift in first gear, then dropping to 4th.... feels MEH....
With the other way, you get the same torque at start (just like any other setting), the exact same as #2 hole, but yoru engine revs really high and you dont really keep accellerating 'faster' its like starting in 1st gear, then shifting up to 2nd, then revving really high.
With all three, the same torque is at start, and the final high speed is the same. its just the #1 and #3 feel 'meh'
take it from goldilocks, just get the one that is just right? #2
Kentucky Boy
Bowling Green, KY
In your pick the driven looks to be halfway engaged already and I'm assuming the engine is not running in the pic. The driven should be closed onto the belt with the belt high in the groove. I'd say it's very dirty and sticking or the spring is shot. Also if that is an original Comet brand the back plate of the driven is slightly different than the Chinese version of the TQ. This could be a problem if the parts are interchanged with the generic TQ's making your spacing incorrect. Look up a parts diagram and make sure you have the correct parts. Also make sure the motor is mounted correctly as it is probably independent of your jack shaft which could also mess up your alignment.
---------- Post added at 01:39 PM ---------- Previous post was at 01:32 PM ----------
Also looks like you may have an extra spacer behind the driven.
branandlee
kartnewb
Central Ohio
Thanks for all the help. Got the new spring in and had to fight with the clip but it finally came off. Got it put back together and drove it around the neighborhood tonight.
Now to work on normal maintenance for it and keep it running smooth!
