Belt ID help needed
Joe M
Pennsylvania
Hello
In the process of restoring a Yerf Dog spider box for my daughter.
The guy I bought it from had the trq converter in wrong and it ate the belt. What I can read is Pix P-5959 0068 D bc 51
What numbers do i use to find a replacement?
Thank you in advance for any and all help .... Joe
that's labelled CVT on GY6 engine's like you have ;)
(continuous variable transmission)
Anyways...
you'll need a 743 20 30 GY6 belt:
https://www.amazon.com/V-Belt-KEVLAR-125cc-Motorcycle-Scooter/dp/B005HYJG54
means it's 743mm in circumference, 20mm wide and has a 30° groove angle.
Wait:
that's the "standard belt" for "standard" spiderbox engines (150cc gy6)
So since you haven't posted a pic of your's we can only assume it's still the one you need of course ;)
Joe M
Pennsylvania
Hello, thanks for a fast reply ☺
the engine was swapped to a brand new predator
The trq converter is a tav 30,
Sorry i should have posted more info
Previous owner gave up after the belt got chewed
The unit wasnt installed with backing plate and jack shaft
Also the pulleys are over an inch out of line
Only the belt has me puzzled with so many numbers ...
an will post pics soon,
Will also post on progress if interested?
for the record, my daughter is 24, I will be doing some engine mods later
For now Step 1, getting it running and driving before complete tear down
I'm interested in seeing progress. We're all better off in the end after seeing a machine restored to proper working order, how it was done and all the troubleshooting involved. Knowledge is power, as the saying goes.
And,
..to the forum.
Joe M
Pennsylvania
Ok got the belt figured out and ordered.
Will have to do some cutting and welding and move the mount plate over. Also possibly switching the axle over. I'll get some pics taken before I start and do so thru the rebuild.
I found the right place to post the build.
Hey if a mod see's this, its ok to put out some good words on a company I see advertised here?
(personal experience with them)
