Belt Driven Cart & Tractor
gmcchamp99
I have both a namco gocart and a tractor with the Predator 6.5HP on them and would like to know how to speed them up without changing to a clutch system. I was told that changing the pulley sizes on the engine and axle will assist with this. Right now the pulley on the engine is a 3/4 bore, 3.25 OD pulley and on the axle, 5 inch OD. What would be the best sizes to get more speed out of it? The engine seems to have the power, i think the power train setup i have limits it.
Atlanta, GA
5 in OD and 3.25 in OD? Without additional information or pictures, I don't understand how this vehicle can move at all. That ratio is less than 2:1.
:iagree:
This may sound strange but, it needs a lower ratio; find a smaller engine pulley &/or a larger axle pulley (around 8"); a good "ballpark" ratio is 6:1, which would vary depending on other factors...
Right now, the engine doesn't have enough torque to reach its potential so, its struggling & holding the kart back; by using a lower drive ratio (higher number), the engine has a better chance of transferring the available torque to the wheels, allowing the eninge to rev higher &, therefore, moving the "kart" faster...
gmcchamp99
Ok so i have a few pictures of the setup on the tractor. It is equipped with a jack shaft from what im told and i have a few pictures of the pulley setup on it. I get that this thing is ancient and obviously as a tractor, it was used to push or pull, not speed. Im looking to convert some of that torque for speed. There is also one pulley on the rear differential that is 8 in OD. The rear end contains a forward and reverse gear as well as a neutral.
I think the gearing on the tractor is about as fast as it going to be.
That type of cone clutch is meant for a certain amount of torque/HP, aswell as the diff gearbox, max. Changing ratios can adversely effect this.
I'm going to bet that tractor clutch has cork friction material.
gmcchamp99
Ok, so to move forward with upgrade than i should change out the cork friction clutch for a torque converter? I can do that fairly easily, removing the clutch assembly, actuator and pulleys then replacing with a TC2 kit. I didn't want to have to go that route unless necessary. I still may not and just keep it as it and use it as a Pull tractor or small driveway plow. it goes maybe 16-18MPH now which im sure if far faster than it did when it was manufactured.
---------- Post added 10-25-2015 at 12:12 AM ---------- Previous post was 10-24-2015 at 11:57 PM ----------
