I like karts
Rotary Power!
Im going to use trampoline springs to keep it tightened when the pedal is not pushed
Nah, I love manual clutches, and I think it's going to go fast enough without a cvt
I used the calculator and 11 inch tires + 8000 rpm + 4:1 ratio = 65mph
And I might be getting like 14" tires later (83 mph![]()
just to clarify regarding the driveshaft water lubrication...
the shaft uses the water pulled in by the turbine to lubricate the o-rings around the shaft. this is why you should not run the ski for more than a minute when not in water...
Im not using that part though. Im just getting the little piece of shaft right off the engine not the prop part
3 pulleys from a scrapyard were $20, and the belt's are $10. Also, here in Australia the centrifugal clutches are a bit more expensive.
It's all ready to go but the belt I got is too long, have to wait until monday to get another
I know many people here swear by the centrifugal clutches but I don't really like them.
yer aussies's who else is here thats aussie. im using a belt centrifugal clucth on my bsr and im actuall confused how they work
