Belt/clutch problem
Captain bottles
I have a gokart that is a Briggs and straton engine and as soon as I start it it takes off. The clutch works fine however and I just can't figure it out please help me.
Rob711
Long Island, N.Y.
High idle. Or broken clutch, you ever take it apart, bad springs?
After I replied I realized this was started in the wrong section.
Captain bottles
I believe the idle speed is not high because when you push it the engine wants to start but I took the belt off and the clutch was working just fine so I never took the clutch itself apart. I've also tried to loosen the belt but that made no difference and sorry I'm new to this.
https://youtu.be/a3FCcLlR-sg
Start here. If you still have more questions ask away.
---------- Post added at 09:29 AM ---------- Previous post was at 09:27 AM ----------
Could you take the shield off and block the cart up and make a video of it running?
---------- Post added at 09:30 AM ---------- Previous post was at 09:29 AM ----------
Perhaps the clutch is gummed up and not opening up all the way and is dragging the belt.
Awesome.
That looks like the clutch isn't disengaging at idle. Mine did that and I took it apart and cleaned everything really well and had to take some sandpaper to the shaft that the bronze bushings ride on. It had some scoring from being full of dirt. Re lubed the thing with proper lubes and slapped it back on. It works great now.
Open that puppy up and show us the insides.
It looks like the belt alignment is off a little too but it's hard to tell from here.
---------- Post added at 10:57 AM ---------- Previous post was at 10:48 AM ----------
I also see a poorly designed jack shaft.
Does the engine mounts allow for movement?
The distance between the engine crank shaft and the jackshaft have to be set at a certain distance for the size belt. It's a one time setup type of thing.
The chain side of the jackshaft is allowed to move for chain tention adjustments.
The way yours is set up you need to adjust the chain tention and lock down the jackshaft plate. Then adjust the engine back to the required place.
The jackshaft must be parallel to the crank also.
Not impossible but a pain for sure.
KartFab
Dallas, TX
what they said, plus this:
The roller weights sometimes jump the track they are on, keeping the moveable sheave from closing all the way.
I thought some of my engines idled just a tad bit too high, but it was actually the springs wearing out, letting the drive unit partially engage under idle. Was barely noticeable though.
My guess is that you have a bunch of crud in the drive unit, just like everyone else is saying. Also, google "comet belt chart" and double check your center to center distance.
