Hey guys, just bought 2 go karts the other day for pretty cheap. Both run (need a new carb and can't find one).
Anyway, had the one running yesterday and had to move the little screw on the carb to give it quite a bit of idle throttle. It's got a tendency to take off when it starts up unless someone has the brake held down. If I move the screw out a little, it won't start at all unless the choke is in, but as soon as you get off the throttle when the choke is off, it dies.
Well with the idle throttle so high, the belt likes to burn when it's sitting still. I cleaned the carb out fairly well when I had both of them off. Is there something I'm missing that the throttle needs to be so high to idle? And is there a way to remedy the belt burning situation if the high idle isn't the cause?
http://i50.tinypic.com/2gtntc0.jpg
http://i48.tinypic.com/30nirdv.jpg
http://i45.tinypic.com/2gwb2ur.jpg
