We've touched on this a few times recently, I thought I'd show you what I've set up. The battery is a gel cell, 7.5AH, 12V. This is the exact battery I have in my computer UPS. They're sealed so they won't bleed acid even with heavy jostling or inversion. It fits in the surplus ammo can with room to spare, so I've got pieces of foam glued into the box to make it a snug fit in there. I welded together a basic tray from angle iron attached to the kart frame, a cam-buckle strap holds the box on. I have bullet connectors just outside the box, so I can just clip my battery charger on without removing the battery from the box. If I want, I can take the whole box off the kart and bring it in for charging. It even has a convenient carry handle!
I love these ammo cans. they'll take a s**tkicking, and come back for more. I have several in various sizes as toolboxes.
This is the safest battery arrangement I could dream up. The abolute worst thing that could happen in a rollover or crash is the strap failing, in which case the bullet connectors would let go, and the box would bounce away, safely containing the battery, protecting it from damage, and me from acid, which is a gel so it wouldn't "splash" anyhow.
