Barry Young Cylinder Heads
https://www.facebook.com/permalink.php?story_fbid=10156059757467884&id=169195402883
Prices on our newest 14cc clone heads are:
Bare head..........................................$30.00
With 28.5 intake seat installed...........$55.00
With 32mm intake seat installed........$55.00
With 32mm intake and 28mm exhaust seat installed. $80.00
Blend seat cut area in milling machine (this is the places in the chamber that the cutter hits when machining for the larger seats)..................................................$15.00
Blend bowl..........................................$10.00 per bowl
Blend chamber by hand......................$20.00
Cut for dual valve springs...................$10.00
Mill head to customer specifications...$20.00
Complete porting of the intake and exhaust runners, and flow testing $100.00
SI brand stainless steel valves (24mm, 25mm,27mm,28mm,28.5mm, and 32mm) $15.00 each
SI brand Aluminum retainers with std or reduced height locks for single or dual springs .$20.00 per set
SI brand Titanium retainers with std or reduced height locks for single or dual springs .$30.00 per set
Single 26lb springs.. $10.00 per set
Dual Valve springs ..$15.00 per set
A complete head will get a discount.
