Band brake got me stumped
Dmplec
Manco Dominator band brake doesn't work. I ordered a new one and replaced the original bolt that was bent. Adjusted as far as it will adjust and still no stopping power. If the brake cable would pull down instead of straight back I think the problem would be solved, but I can't figure out how to accomplish this. Any ideas?
Dmplec
Could a slight bend in the axle or the axle/brake drum be warped a little and this is allowing the band to open a little instead of fully seating around the drum? I did pull the axle and noticed the keyway was deformed a bit and when I spin the wheel it wobbles slightly. Dmplec
Dmplec
Here is what the axle looks like on the wheel side.
Ebrownie
Western Montana
Do you have enough leverage at the pedal? Band brakes just aren't the greatest in general, but still work well when set up correctly. Is your linkage bending or something? I can't see why it wouldn't work from the pics, unless I am missing something.
Staff Murderator
Try flipping the band over, effectively switching holes on the mounting pegs.
Looks like you have a cable brake actuator. Steel rod works better and in fact most brake actuators across the brands use steel rod; about 1/4" diameter.
you sure you got the correct band?
there are 4" and 4.5" bands if you can buy a 1036 manco labelled
(I for one miss the bracket on your band!)
degrease the drum, and give the band a few strokes with a scotch brite for good measures
it should work just fine.
the cable should sit at a slight angle (I can't tell from your pic tbh)
pulling "slightly" down
(towards the cross member of the chassis where the cable should be fed through)
Oh and yes.. cable.. do not use cheap flimsy cable (which is plenty good for a throttle cable or kid bikes)
use heavy stuff (like you'd find on vintage automotive throttles or some 80s BMX bikes)
Staff Murderator
The plot thickens. The model 435B/C Dominators use a brake cable.
I agree with Sid's views though. Your band might be too big or you're not quite pulling it at the correct angle.
Dmplec
I bought the 1036 band. I also flipped the band and raised the brake cable to the 2nd hole at the foot brake. I tightened the cable as rich as she will go. We will see tomorrow if it works any better. As far as the angle the cable runs through the factory hole that is angled up. I think this is the problem, if I could modify it to pull down I would have something.
Dmplec
Previous post no bueno. Tonight I rigged a piece of angle to lower the brake cable position to the frame. I kept lowering it and lowering it, no good results And it made it worse. So for ships and giggles I figured I would raise it and what do ya know it freakin worked. Band brake conquered. Now if I can figure out the torque converter conversion with a jack shaft. Thanks for all the input.
