Hi guys-
I have an old Manco Dingo 285. The brakes are terrible and after getting into this I realize that the existing brake drum appears to be slightly cone shaped. In other words the inboard side is slightly larger than the outboard side, if that makes sense.
Do I need to replace the drum, or is it supposed to be that way?
The brakes are plenty tight but the band sometimes rolls over the drum, how can I fix this?
My last kart the band would lock up the wheels, this band appears to not create enough friction, there is plenty of friction material left, should I also replace the band?
Thanks!
Thanks!
