Baja triple tree bearings ?
Walter Keller
tampa bay area
Baja steering head bearings look like the same used in bicycles ......true or false . I need a set for a build we are doing. Who stocks them?
We too are also replacing the front forks with a set of the larger diameter 28" long ones from gopowersports - welding on clamps to the existing steering head for the larger dia full length forks.
As long as you keep it tight and well lubricated, it should be fine...
I'm surprised it had bearings..
I used a good set I found, cleaned the cups and re lubed caged race...
Works great..
