baja heat project (need help)
Big foot
Maryland
so i started my baja heat project and i was wondering if anybody has built one of these before.i took out the governor and low oil sensor so far.now i need to do a throttle linkage and a few other things.if you have any pics or comments please post.thanks
kendelrk
redneck engineer
westland michigan
the best mod for this bike is a torque converter, enough torque to pull up the front wheel and enough speed to keep up on a city road, they run around 130 $ for a china system and youll never regret buying one. i can also suggest a number 90 main jet, exhaust and an aftermarket airfilter. better yet, heres how to do the linkage for no governor http://diygokarts.com/vb/showthread.php?t=15203 and please tighten up that chain, its way to loose, you should only have 1/2 slack. if you plan to do alot of wheelies, you may want to reinforce your mount. after the TAV and even before i cracked the front left corner of mine doing them. also take out the throttle stop screw when is right by the throttle arm, and no matter what is said. unless you plan on going with a billet rod and flywheel dont change your valve springs. valve float occurs at 5500-6000 rpm and will save the flywheel and rod from going, if you change them the valves wont float and you will have a chance of blowing it if you dont have proper upgrade parts
Get a good look at pic #3, showing the output shaft. Your sidecover oil seal is damaged. That thing's gonna drool oil all over the place. Order a replacement before proceeding.
Big foot
Maryland
thanks alot guys.nice video also.yea that was one of my questions with the oil seal.i was wondering where i get a replacement.i do plan on a torque converter.ill look at the linkage write up and see if i can do it.thanks again.ill have more pics soon.
kendelrk
redneck engineer
westland michigan
ebay a china system is 130, but you do need an angle grinder to chop part of the backplate. and oil seals you can get online or from a local store, i think you should go online and get an oil seal, and a side cover gasket just for the heck of it.
Big foot
Maryland
yea thats a pw50.yea lil monster truck has a briggs and stratton acohol motor.i had a jr dragster when i was younger and i took the motor off and put it in that.im in the progress of putting a 250ex motor in it now.needs reverse.ill put pics of it up soon
Big foot
Maryland
the monster truck is getting restored also.the baja is in the powder coater shop now.i will have pics asap.
r_chez_08
Should be in the shop...
Cornwall, UK
You got the oil seal yet? If not search for Honda gx160 and gx200 parts, clone parts, box stock, BSP and more. Check eBay, NR racing and doverpoweronline.
Big foot
Maryland
yup got a bunch of parts from agk.hope to be putting it back together asap.working on my r6 right now.did a 520 swap and -1+2 sprockets.
