Baja Clone. Problems.
B.M.800
TheBeal.
Central PA
So It seems, that when I get another engine running, the one I had running before it is konked out. What the crap...
So this time, its my Baja Clone. It dosnt seem to want to fire.
I have the muffler off and see smoke and fuel come out.
Whats the deal?
:huh:
Thanks!
{EDIT} Oh and there is spark too... obviously, can tell from smoke. Right?
:D
B.M.800
TheBeal.
Central PA
compression? spark? fuel?
sounds like a fuel mixture problem to me or a valve not seating
Valve huh? What be the best way to determine whats going on?
If its to deal with fuel mixture, it ran fine during the fall. Maybe something gummed up in the carb...
i dont mean to start an argument, but put the muffler on and try firing
No good. I took it off to see if there was anything coming out... jus smoke an fuel.
Thanks for the replies.
slideways
Did you say because it smokes that it must have spark? Really?
Did you check the low oil sensor or oil level?
r97
Measure twice cut once
Massachusetts, USA
I don't remember exactly, but I believe to check for a valve that is not seating you should run a compression check. If its too low, pour some oil in the plug hole and check again. IF the compression increases your problem is likely in the piston rings/bore, if not it could be a head gasket or valve. You can put soapy water around the head gasket to see where, and if its leaking.
Check valve lap and turn the engine CW (from PTO side) when doing compression check to override the decompression.
Check that spark plug is clean (oil could be a sign of worn rings/bore/overfilled/engine tipped on its side) and that it actually makes a strong blue(right?) spark
B.M.800
TheBeal.
Central PA
Looks like Ive got something to do tomorrow! Thanks.
Ill update if anything new happens.
Not sure if we have a comp tester or not though... that could be a problem.
:roflol:
{EDIT} Err... not tomorrow... later today...
I need to got to bed. lol.
slideways
Not sure why on a newer motor we are jumping to compression and valve problems right away. His basis so far of the motor having vs not having spark is seeing smoke from the exhaust port. Did you pull the plug out and see if it actually has spark yet? Did you check the oil amount and make sure the low oil sensor isn't causing your entire issue? Have you tried a new plug?
B.M.800
TheBeal.
Central PA
Yup I seem a spark, not the brightest, but clearly visible in the light. I dont believe these motors have a oil shutoff switch. Also oil is fine...
I might, just take the coil off this one and try to get the Honda running... as much as Id like genuine honda parts on it. Am I crazy for that? :D
kendelrk
redneck engineer
westland michigan
naw, not crazy, and i know this sounds stupid. with my old, old, old clone i could see a spark but still nothing, i put a new spark plug in there for the hell of it and she fired right up, so even tho you can see a spark dosent mean its going to fire up the engine
B.M.800
TheBeal.
Central PA
That something I been meaning to do... gettin sparkplugs for all my running/could be running engines. About 5... maybe. lol.
kendelrk
redneck engineer
westland michigan
i say if you have another good running honda/clone gx200 take the plug and try it, my problems were spark plug and the carb
B.M.800
TheBeal.
Central PA
Not sure where our gap tool is, and besides Im thinking the plug hasnt been changed ever(atleas not while I had it lol.) If that dont do it, Im going to rob parts for the actual Honda.
