Baha MB200 Problem Starting
sbt1128
Had some work recently done on MB200 now it's incredibly hard to start. Have already gone thru 2 starter assemblies. Pull rope is very hard to pull and every so often, the recoil snaps back so strong that it screws up the starter assembly beyond repair. I won't replace starter assembly now until something can be done to reduce the compression. Any thoughts anyone?
Thanks, Steve
KartFab
Dallas, TX
just something that i read online, definitely check valves too as mentioned above:
http://outdoorpowerinfo.com/repairs/flywheel_key.asp
"If the sparks occurs during the compression stroke, the engine will backfire, and the crankshaft will reverse direction violently. If the operator was pulling the recoil starter, the starter rope would be pulled back sharply, along with the operator's arm. This is a common and painful occurrence, and a sure sign of a sheared flywheel key. "
That is an excellent article Kartfab!! I have added it to the Helpful Links thread
