Backfires & Staight Pipes
qtband
St. Louis, MO
Sounds like a rock band don't it...
The last two engines that I put straight pipes on, backfire upon deceleration. Is this normal?
Also,
I made one from 3/4 tubing, welded the end and drilled about 12, 3/8 holes in the end. Then I welded a larger pipe over the drilled end. It sounded good and didn't backfire nearly as much, but am I doing any good with this type of set up?
88nightrider
Norway, Sandnessjoen
Might sound a bit strange, but backfire usually (from my experience) come from a lean burn state.
My first thought is that your straight pipe works really well :thumbsup: Meaning that it kind of makes a vaccum in the exhaust. So might be too much vaccum for the carb to deliver enought fuel when you let off on the throttle.
Could you check your spark plug?
Edit: What other mods?
Air filter?
Stock carb? Or any changes?
qtband
St. Louis, MO
There's a new plug in it.
I have a 19 mm slide carb on it and a small air cleaner on it right now.
I would have a stock exhaust on it but I don't have one.
BTW, Honda 5.5
Not to contradict you, nightrider but, the literal explanation for a back fire is "an explosion of unburned fuel ignited by the heat of the exhaust"; that would tell me that you're either running too rich or the fuel is not being burned properly in the combustion chamber...
Do a plug test & report back
qtband
St. Louis, MO
When I do the plug chop, do I have to be under load or can I do it with the engine mounted in the kart, no chain?
Half-breeder
"Edit" button removed
When the engine is cold... remove the spark plug... take a pic of it... post it.
If its dark n wet... your running WAY rich... if it's white n dry... too lean... youll wanna see something in between them... post a pic n we'll tell you.:thumbsup:
It's good to run just ALITTLE rich(for enough fuel, for sudden accelerations)... but if things are too rich youll endup w/ the issues you got now. IMO, your jetting may be opened too much.
firemanjim
Just kartin' around....
Houston Texas
:iagree:
Backfire is unburnt,spent fuel in the exhaust pipe. The build up of said fuel erupts into a tiny explosion, heard as a "backfire"..... It could be that the OP is just plain running too rich, or just rich enough, that upon deceleration, he is leaving gobs of fuel in the pipe..... :thumbsup:
My gx160 (modded) now backfires a little on deceleration after a good thrashing...... Runs like a rocket otherwise.....
Gokartbill
Atwater,Ca
Definitely not a decrease in power for me. Burnout and power slides for days!:thumbsup: Must just be running a little rich. Does backfire couple times apon deceleration.
TheNewCarter
Thy Art is Murder
Woodland Hills, California
So minor backfiring is okay for these engines then? I just added the OMB upgraded bolt on kit and mine backfires upon deceleration a couple times too and sometimes shoots a tiny bit of fire after WOT and quick release of the throttle. I used the .36 jet instead of the .37.Ill post a video tomorrow and a picture of my plug. I am running the velocity( i think) RLV header. I don't like to use the muffler/silencer it doesn't sound as mean haha. My neighbors must be hating me now.
EDIT: I haven't installed the 4 degree timing key it came with yet or 18 pound valve springs.
fowler
Bullsbrook West Aus
What Russ said
Not really a problem
It's more likely to happen with a straight pipe
I guess because of no muffler to stop flame
Unless it's doing it intermittently at any point of throttle then I wouldn't worry about it
A bit on deceleration isn't uncommon on a tuned up engine
qtband
St. Louis, MO
That sounds good. I ended up adjusting the needle on the carb to make it a little more lean and most of the backfire from the exhaust has disappeared.
