qtband
Sounds like a rock band don't it...
The last two engines that I put straight pipes on, backfire upon deceleration. Is this normal?
Also,
I made one from 3/4 tubing, welded the end and drilled about 12, 3/8 holes in the end. Then I welded a larger pipe over the drilled end. It sounded good and didn't backfire nearly as much, but am I doing any good with this type of set up?
Also,
