Back at it again with the dead engine
New2Dis
Naperthrille, Illinois
Since it's getting a little warmer out (30 degrees F to be exact) I have decided to put a resolution to this dead engine that has no spark. I'm pretty sure it's due to the wiring, I've just highlighted the wiring. The one wire comes out of the engine and is fastened to a bolt which another wire is fastened to that leads to the switch. Can anyone explain to me what to do, I'm kinda new to engines and would love the dumbest downed answer I could possibly get. I don't know how good the quality is but the letters just say, "this wire leads to the switch"
thats the killswitch (it's wire that is ;))
short the end of the wire to ground (say the engine case) and it'll prevent the sparkplug from firing.
that wire must NOT be attached to that bolt on your engine
If that wire is shortened out somewhere (like with your bolt), that's indeed the reason your engine doesn't spark ;)
lose the bolt, insulate the wire and try again... report back :D
well, yes and no.
No, with spark, compression and a ignitable fuel/air mix, there is nothing else needed to run an engine..
Yes,
just because the plug fires when you hold it to the engine and crank, doesn't mean it'll spark when it's screwed in;
could be the spark plug needs to be replaced, could be a cracked spark plug boot, could be a broken spark plug wire...
and just because the fuel reaches the carb doesn't mean the carb can mix it into the air (what about a blocked jet, or a frozen float valve for example?)
So, I'm afraid you'll have to check everything again.
Poboy kartman
Senior Moments Member
White Settlement Texas
Yeah.....ummmm...shoot some carb cleaner into the carb with the air cleaner off....I'm betting it runs for about 10 seconds....
If so...you need to completely disassemble the carb and clean or replace....
Let us know...:popcorn:
New2Dis
I took the carb completely off the engine, cleaned it with carb cleaner then put compressed air through it. I will replace the spark plug again because it's doesn't seem to be catching.
Poboy kartman
Do you have any idea how many times I've told people they need to clean their carbs after they've cleaned them three times????
Spray the frigging carb cleaner and try to start it......
Jeeze....thought you wanted help....
