B&S Only Runs Choke Half Open (Manco Dingo)
ZMan524
Southern Wisconsin
Hey there go-karters! This is my first day and post on this awesome site!
I just got a used Manco Dingo a couple days back and have been trying to figure out why it wont run without the choke being on full or half open. As soon as I move it to full-open, it revs up and down a few times, getting slower and slower till it shuts off. I'll put up some info on the engine and kart for you helpful folks.
9.5hp Briggs and Stratton Vanguard Model #185437-0087-01
Single Cylinder OHV
Horizontal Crankshaft
Not sure what model Dingo (Single seat, says "Dingo IX" on back)
Comet 40 Series Belt Clutch System
Link to the manuals for it: link
I think something may be up with the governor or air-to-fuel ratio because it can never keep a close-to-steady idle and always revs up and down to a great degree.
I've disassembled the carburetor and cleaned it as thoroughly as I could in an hour. Doing that let it run on open-choke for a little longer, but it would still shut off... unless I moved the governor linkage back and fourth quickly, somehow keeping it going.
Any help is greatly appreciated!
ZMan524
Southern Wisconsin
How do I adjust the air to fuel ratio? I had an older B&S lawnmower engine that was a breeze to adjust.... cant figure this one out.
I'll pick up some new gaskets and more carb cleaner.
Yes, it's a bowl. When I cleaned it, the float and needle seemed fine, no stickage.
Russ2251
AZUSA:Powered by LAWN-BOY
No can do, thanx to the EPA.
Remove main jet, emulsion tube etc. and inspect ALL holes for blockages. Use compressed air and bread tie wire to help clear passages. Use an eye loupe to inspect.
The tiniest particle can muck things up.
Ummm... Newbie question... What's a Welch Plug?
Here are some pics of welch plugs on Briggs carbs. You can take them out and then check for clogs etc like Russ said. I am not 100% sure, but I think once you take them out you have to replace with new ones.
Have a look here for some more Briggs info. Its a great site for help if you need it
http://outdoorpowerinfo.com/repairs/
ZMan524
Southern Wisconsin
Thanks for the info, landuse!
There's good news, and bad news.
Good news is that I got it to run on open choke.
Bad news is that now it won't shut off when I turn the key off.
After I got the carb all mounted back up, it started up easy, would only run on closed and half-open choke (no open yet). I was holding the throttle on the carb, and suddenly it's rpms start increasing out of control, even when it shouldn't be getting the gas or air to do so because I was holding the throttle closed at that point. I flipped off the key, kept going faster. I was forced to pull the spark plug wire for it to finally stop. I don't think I've ever had it running that fast. I started it up with the key OFF and it ran on open choke just fine, no going out of control or anything. I don't understand this engine!
juvius
extra special
plymouth, oh
make sure that when the key is in the off position that it's sending a ground signal to the stop switch...
