B&S 5hp Engine
Snype2live
I have a B&S 5hp, I have removed the govenor and put a three horsepower flywheel on it and a custom exhaust of of a mini crotch rocket and Im just looking for some suggestions on building this and making it faster.
solomon
ca
swap your 5hp flywheel back on it for torque. You will need a custom bracket for the coil to work with that flywheel. Remove that exhaust a 3/4" straight pipe about 14" should be good. Did you pull the internal governor and washer?
solomon
ca
Doubt a mini crotch rocket would need the extra torque, i would just use the 3hp one.
He said he used the exhaust off a mini bike, probably a 47cc and thats a 2 stroke pipe, it will make the motor lose power, by reducing flow.
Snype2live
yea it is a much smaller pipe and i didnt get a custom bracket for the coil i just customized the coil :) and how much would the 3/4" 14" pipe affect the engine
solomon
ca
you can gain somewhere around .75 HP from a straight pipe, you can get that at the hardware store for like $7
Snype2live
awesome...anymore suggestions ...they are greatly apprciated..i think im going to get some pics and post them on this thread so you all can actually see to judge and make suggestions
solomon
ca
you should really use the 5hp flywheel for the extra torque. Port the intake valve slightly, shave the eyebrows, eliminate the head gasket.
Snype2live
explain the shaving the eyebrows, i just got into this not really sure what that means sorry.. but i been in mechanics for two years so im great with tools and engines just not the lingo yet ...and i heard that the 3hp fly wheel will advance the timing 6+degrees and will increase the torque?
Snype2live
ok will get u some ...ugghhhhhh!!!!!!!!!! i broke a bolt of in the pto side of the crank shaft
solomon
ca
Bummer, use a drill bit and tap it to the next size, or leave it, and use set screws on a clutch
Snype2live
could i just use a clutch with set screws? and where would i get one cause all i had was a torque converter and its belt driven
solomon
ca
Drilling and re tapping isn't that hard. Does your motor use the starter cup or starter clutch? If its the cup style starter, I have a crank i would let go of for cheap.
Snype2live
it is a cup style and yea i know it isnt that hard but i dunno if i have a drill bit hard enough to cut it
Snype2live
OK so besides the cheap project im doing im actually thinking about investing the money and buying a good block and building an actual racing engine so where and what would u recomend starting
