B&S 3 HP 5/8" Shaft adapter
buffaloglenn
Texas
Does anyone make an adapter to go from the 5/8" shafts to a 3/4" width shaft so that you can then use a comet 30 torque converter? I have access to a few of these and have a good TC I would like to use. It seems like there would be something available to do this.
augidog
food for thought: seeing as a standard-depth key is built into the Comet driven pulley, it may not be deep enough to properly lock both the adapter sleeve and smaller shaft.
souperman000
Westlake Village, CA
here is mine. we used a lathe and made this adaptor used set screws and a keyway to keep it in place. 1" down to 5/8"
r_chez_08
Should be in the shop...
Cornwall, UK
I made an adapter, 3/4" to 1". Not too hard, all you need is a tube 5/8" I/d, 3/4" o/d and some time.
