Johnnyboy
Hey guys, I'm almost at the end of a 3 month restoration of my Manco Rattler LXT. However, the old brake pads were so worn down (new brake pads moved the break rotor about 3/8in to the Left), and two new rear axle bearings (flanges extend 1/4in longer) have shifted the axle.
Now, with the two stock axle spacers, which fall in between the Left axle bearing and the brake rotor, my brake rod does not align properly and rubs into the rotor. My question is, do I even need these two spacers on the axle. If I have spacers in between the rear wheels and the axle bearings (outer axle) wouldn't that alone prevent axle movement?
Thanks!
Thanks!
JK....
). After a little trial and error, I bent the brake rod into position and it now fits without issue. I plan to finish up the restoration this Monday. Can't wait!
