ONE-EYE
So I've been assembling a new axle for a 3203 and the kit they sent me didn't contain a spacer between the brake drum and the welded flange. Without one, it seems the drum would rub on the flange so I opted to try and use the one off the old axle. It looks like it might work but I wanted to make sure because it seems to fit pretty loose on the axle but not loose enough to sit on the bearing itself. Would this be ok to do without causing any bearing issues? Also, does it look like I'm setting this up right (as far as the positioning of the collars)? I don't have any key stocks in just yet so I wanted to make sure before I started sinking everything down. Thanks guys!
(everyone has their "personal" preferences)
