Axle bearing help
Wendle
I bought a carter 2336 -3017 for cheap for my boy. Im going to replace all the bearings there shot. I got the drivers side hub off and it's down to just the axle on that side. Can I just knock the axle out the other side to replace the axle bearings or is there another way.
Wendle
It does have a tube no bolts from behind and no set screws on bearings. Way it looks right now I'm going to have to throw some heat to the bearing and beat the axle out. With the nut on the end so I dont mess the threads up.
Wendle
Here they are
taotao110d
SPP_MN
I have a carter with an in-tube live axle like that. I used a block of wood and a sledge to beat the axle out one side and a random pipe to beat the bearings out from the inside. Got the new bearings from gopowersports
Wendle
I just got it out there is a washer on the driver side that wont let it go out the passenger side. So I took hub off that side and used a mallet it came right out the driver side
Wendle
Now that I have it out .looking it all over the wear rings they call it in the breakdown is wore out all the websites I looked on don't have them where can I get one
Wendle
Here it is
I reckon that washer just offsets the bearing from the cup where axle tube resides, as to not allow the bearing to press up against that tube and damage it. Hence why its worn from the rubbing of each other.....
A washer the same size and thickness will do, or just clean off the old one free from burrs and grease, reinstall.
