Hello,
I am hoping to get some technical assistance with a go kart I am repairing.
Part #AZ1412-40 (1" Deluxe Flexpruf Solid Steel Axle Short End 40") was backordered. http://www.mfgsupply.com/m/c/AZ1412-40.html
I want to make sure I am doing the right thing.
The kart was originally a 5hp single wheel drive kart. The axle (which bent) was 1" diameter and 36" long. It was held in a "live axle setup" The single drive wheel often slipped.
The frame dimentions are 26" frame (bearing hanger to bearing hanger) and the tires were placed 35.5" apart (center to center)
The old axle appeared quite different than anything I've been able to find, so I'm winging it. The drive side of the axle was 1" and threaded. The other side stepped down to 3/4"- about 5" from the end and held a hub with bearings (free wheel.)
My general plan was to switch to a bilateral live axle. My kids use the kart on grass. It has 13x5x6 turf saver tires and a centrifugal clutch.
I purchased these wheel hubs, 53-681 (Steel Hub for 1" live axle. No step) http://www.mfgsupply.com/m/c/53-681.html
My questions are as follows.
Will I burn out the centrifugal clutch with these small tires on grass? I would really like better traction.
Will the above axle, with the 37" shoulder to shoulder, get me to the place I need where the tires are about 35.5 inches apart as before? According to my calculations, if the hub is "centered", I should be approximately 35.5 if I let the hub hang off the end of the axle about 3/4".
Will I need spacers to hold the hub in place against the bolts at the end of the axle? If so, where do I get them?
Thank You!
Thank You!
