axel bearing help
mhero
below are descriptions of the new axel and axel bearings I just received. I cannot get the bearings to slide onto the shaft, I can get them about 1/8" on to threads @ the end of the shaft. I don't want to damage the threads or new bearings. So I ask the experts..... what's the trick?
Axle Bearing - 25mm Bore(600642)
Axle Shaft - 1" x 39-3/8" (01132)
•1" axle x 39 3/8" long
•Has staggered 1/4" keyway:
3-1/4" from each end and 3 different spots through the middle of the axle
•9 different snap ring locations
•1" of thread on each end
fowler
Bullsbrook West Aus
1" = 25.4 mm
A 25mm bearing won't go on a 1inch shaft
Sorry but u are up for new bearings
Where did u get the bearings from?
If u get real keen u can pick seals out and clean the bearings
Heat them to 130-140 *C, then try to find a pot big enough to drop the axle into nitrogen
Then press the bearings on
But 0.4mn is some serious crush
scarletvw
Minnesota
1" = 25.4 mm
Getting the bearings on would be one thing, but what about ever needing to get them off :ack2:
Don't bother with using the wrong part, pick up the correct bearing and do the job correct once :thumbsup:
mhero
dam those pesky decimal points. I've got some 1" sanding wheels, I'm going to try to modify one (the bearings were only $1) but will be ordering 3 more if that fails.
