auto transmission on preditor 420cc
truitt
joplin MO
my 2003 Honda 650 had a auto/maunual transmission. im putting a preditor 420 in my buggy/go kart and was wondering if I could get a Automatic atv trans and put it on my 420cc with a 1" shaft
You can't just bolt on and go...
You'll need to make it work....
How much work.... depends on the trans.
Thats a pretty custom transmission.
Depending on the donor motor, it might need a new "crank" acting as an in jackshaft, with what ever needed machined to accommodate a sprocket and the piston delete.
Some I have see are a motor completely sawn in half, to separate the trans from the crakcase.... A new partition plate fabbed up to make a sealed reservoir for the trans gearbox.
All in all.... its work and alot of it..... can be done... with time and patience.
