Jet, to be frank, if you don't take anyone's advice, and suggest it is probably a different problem, then you not only ruin your chances of fixing the problem, but others that know the answers will not give them to you, knowing that you will reject them.
So please, listen to this sound advice quoted below:
OK...
IMO... that belt
NEEDS replacing... that's
#1 off tops (
a new belt is 2x yours width and is asymmetrical... yours looks to be a V-belt... V-belt=20series)! Next, that driven looks alil worn (
belt isnt suppose to sit so low in the valley at idle/rest). Have you lubed it (
taken it FULLY apart and lubed the slide/race)? Suppose its possible the spring is worn (but Im suspecting
not preloaded...)
... driver 'looks'
proper, but one can
only tell w/ the clamshell off.
This belt is total crap. TOTAL CRAP. replace it already.
If you dont know how to replace it here is where you need to find the answer just follow these basic steps
1) click
here, and find the 30 series with 6" driven unit column (its probably a 6" just looking at it but you can measure it with a tape)
2)pull out a tape measure, and measure your center to center distance (explained on the webpage in step 1)
3) write down or copy the belt number(e.g. Belt 203591A, just copy 203591 and type 'comet belt 203591" in search), put it on ebay and buy the belt. a GENUINE comet belt will last a long time, and has better performance, versus a chinese belt they both work but the comet is better.
4) wait for the belt to come in the mail
5) install the belt
6) belt problem fixed
if you cant follow these exact instructions, then you will get nowhere. Sure people can explain why, but who really knows why some crap belt worked in the first place? it was probably magic, so just fix it by putting on a new belt.
Also, judging from your last post, that go kart doesnt look like a yerf dog. Most of it looks just like a manco go kart (pedals, spindle brackets, motor mount, axle protector, sprocket guard, sprocket hub). What makes you say it was a yerf dog? it looks similiar to a manco model 285 if you want to look it up.
Good luck! I hope you can fix your BELT problem, (its not your engine btw, just in case you think it is something else, it really REALLY is the belt for sure like no doubt 100% your belt)
