like I dont have enough projects already-rescued mower project.
It all started 2 weeks ago, when I was about to go on my 1 week vacation. A couple of weeks before that we had decided to scrap an automatic 18.5hp murray rise on lawn mower. The mower had a working engine and ran good, but the hood was cracked to ****. That plus a burned starter selonoid, a few more details, and the fact that we already had two other good working lawn mowers made us decide to scrap it. At first I tried to swap the engine into our john deere mower which has a weaker engine, but I ended up burning the coil on it... so I decided to just put it aside and leave it as a spare engine. I dont remember what it was, but right before I went into vacation I got the idea of using the components from the soon to be scrap mower to make a fun machine, something on a budget, nice and low and hopefully capable of at least pulling 15mph. After I had a quick look at the mower and looking at the big beautiful diff/transmission we were about to throw away I was convinced. The next day I went to buy some 1" 14ga square piping, and on my very first day of vacation I went at it.
So, here's the plan:
Make a "go kart" using as many of the already existing components using all of my skills to make if as cheap as possible. It has to
1-be cheap
2-be sturdy and stiff
3-be low
4-do at least 15mph
5-easy to drive
So, my first day of this project, i went at it.
First things first, strip and see what I'll be able to use from the mower:
Measure, measure again, cut and tack. Im a happy camper! I had considered buying a cheap car to redesign it as a tubular running structure, so this is a good test. As much as I'd love to make the chassis out of tubes, I dont have a pipe bender nor cutters so square piping will have to do it for now.
mocked up 300zx seat
mocked up gas tank, battery tray and differential location
starting on the front suspension carrier. This was done working around the lawn mower suspension. I grabbed the mower axle and cut it in two to make the front susp independent
I didnt like adding this much weight but I couldnt figure out any other way to make it strong enough
deciding on engine placement
Engine sits so high, and I of course dont like it, but I couldnt find a way around it. I even cut the sleeve where the drive pulley is welded so it could mover further up to move the engine lower.
I was able to use the mower's steering system by tilting the whole system nearly 90 degrees and re-welding the steering arms at an angle and changing the location of the knuckle steering arms
1-be cheap
3-be low
4-do at least 15mph
5-easy to drive
