Are all manco dingo's the same size?
Filipe
06095, CT
Hi guys,
New here, but are all the 1 seater manco dingo's the same size? Like lengthxwidth??
Thanks!
bighead
Pacific Northwest USA
I know they made a open cage style and then full cage style later on. Not sure on the specs though.
Some have round axles while some have octogon axles. I have had both types and do not remember one being bigger or smaller that the other.
Filipe
06095, CT
Well I've sat in a 8hp and I fit fine. But now I'm looking at a 5hp and it would be far enough that I'd have to buy without seeing. I just don't want to get screwed.
Filipe
06095, CT
Sorry, I was trying to make a long story short. Let me try again.
At one point I was interested in an 8 hp Manco Dingo Go Kart. I went to go check it out, test drove it, etc. I found out that I fit fine in the 8hp Manco Dingo. I did think it was overpriced, so I didn't buy it. Now, a few weeks later, I've come across a fairly priced 5 hp Manco Dingo. Since it is an hour and a half away, the owner doesn't want to drive all the way up to my house unless I can nearly assure him that I am going to buy it.
So, I am asking if all Dingo's are the same size, because if they are, that would mean I would be just as comfortable in the 5 hp one as I would in the 8 hp one.
Follow?
Now I do, thanks for clearing that up.
You would assume they would be the same in that respect. Probably the easiest way to find out is google them (for specs) & compare the difference.
In saying that, do you know if the 8hp was stock? Someone may have put an 8hp engine in a 5hp kart... it happens.
Filipe
06095, CT
Yea, Im going to say it was stock, though I suppose I will never know...
Unfortunately, no specs are available, from what I've searched
Filipe
06095, CT
I also assumed it to be the same. Just wanted to make sure other's agreed. If there is a difference, it surely isn't noticeable.
