Arc welding with a battery charger?
02mx-5
Orange County, New York
Is it possible to arc weld using a large battery charger? I hooked it up to my pocketbike to start it and touched some metal togeth by accident. it looked as though i was welding as i saw the arc. If i were to put a rod in the positive clamp could i weld if i set it to 12v high?
oscaryu1
12V charger can't keep up with the amerage flow, and won't start the arc at all.
With my pile o' batteries, 200-300V is achievable far too easily lol.
Although charging them back up will be a PITA.
frederic
The Junk Man
New Jersey
You can stick weld thin stuff (with a thin rod) with a single car battery. It's difficult to strike the arc and maintain a welding puddle however. 24V (two batteries) or 36V (three batteries) is the range I'd recommend playing with if you want to weld with car batteries. I've done it many times and it works reasonably well.
Car and truck alternators work well also and you can use an old interior/dash light dimmer in series with the field coil to control current somewhat. Obviously not all welding jobs demand full power and thinner stuff can blow through.
A car charger can provide it's start rating only for a few seconds, typically 15-20 max. These things are designed to suppliment a weak battery and not replace it entirely. This is why if the battery is completely dead you cannot start it with a charger/starter - the battery isn't helping at all and probably sucking more current than the stater, at least initially.
Just be very careful. Amps can kill you very easily.
Raywelder
Not an Adm¡nistrator
Youtube it!
I did last night and theres a really good video demonstrating how to do it, I was impressed on how good it welded, considered they are car batteries.
freakboy
the names 'mater
hick town
U could probaly hook a tractor generator or two up to a pully system and engine and make some sort of circut to make the flow variable and then you use jumper cables and walla.
r_chez_08
Should be in the shop...
Cornwall, UK
i touched the two terminals together on a small 12v battery charger, and it seemed to create a small arc.
oscaryu1
I can see this ending badly.. Very badly..
Even if it didn't arc and just stuck and shorted, the batteries are powerful enough (SLA car batteries have major amerage), it would just burn and glow the stick/wire up until it fried.
No harm done, happens if you're bored with a wirefeed ARC too.
Kenny_McCormic
Kartless....
Michigan Troll
According to my old man, back in the day before he had a real load tester he would short batteries with a piece of coat hanger wire. If it burned the wire in half, it was a good battery.
