ARC Billet Flywheel for Clone = $100 and more!
oscaryu1
Been readin up some threads at 4cycle eh? :p
But $100! You save $50 if you buy there too! Their filter adapters are dirt cheap, ect...
oscaryu1
Dyno Cams?! They pretty make most of the cams out there! AGK carries their $50 .265" lift cam.
This is a .265" lift Dyno cam. This cam is designed for use with larger than stock carburetors. Duration is 236 on the intake and 236 on the exhaust. No block clearance needed for this cam. Drop in and go! This is our best bang for the buck, top choice.
I've gotten a cam from ARC, but they said they had to send it back to Dyno cams due to a incorrect grind. Got my cam, very pleased with it.
