Silvergrizz
Regarding the first part of the question about the length of the a arm and the tie rod. If they are both the same length it is ok, but for the pic shown if you did this then you will have to alter the arm on the spindle and this will affect the ackerman.
I am not planning on altering the arm, I was just trying to show where the might be equal, as the arm is about 3 inches long and even with the top of the spindle, I am guessing it might be close to equal. I don't have my 5/8 heim joints yet to finish the front end, so I can't install the spindles to measure. The spindles are just the cheap ones from BMI labeled 1 and 2. I don't think Bill has his heim joints yet either, or he would have completed the assembly.
If you are going to use a short shock so less travel, you could most likely dial bumpsteer out by moving the rack. Town the road though you might want to go to longer shocks. Bumpsteer is bad because it feeds back up the steering to your hands and the front end dart from side to side if bad.
Those are the shocks specified in the plans
The best thing to do is to make a new front end, save a lot of time and headaches.
Actually, before I do a redesign, I need to completely assemble the front end according to current plans to see how it all measures up, so I can fugure what needs to changed.
Do the plans show ackerman??
No
well you know the rest. I will wait till you get this all together for verification before I make these mods, but they look awesome
I was asking Theo a few questions based on your pictures since you are farther ahead than me on the front suspension build. Sorry, did not mean to do that.
