AR3910X Questions
HONEYBADGERFTW
Houston, TX
I've searched the forum and haven't found the answer so I'll ask, is the AR3910X spark plug ok to use on a predator 212 non-hemi, with GPS intake, .038 main jet, and open exhaust header? Or is there a "better" plug? I'm aware that it's an opinion based question and will get mixed answers, but any info is helpful. Thanks
65ShelbyClone
SoCal
The main, and perhaps only reason anyone uses them is because they slightly increase compression in kart classes where the head can't be milled. It's also a very cold plug and will be more prone to foul in a general purpose application. Those class karts run WOT almost all the time.
My suggestion would be to use an NGK like the Hondas come with or an equivalent. It's 300% cheaper and works just as well or better.
Joe-405
Enjoying New Projects
U.S.A.
I tried the 3910x and the regular ngk. Ran like crap with the 3910x and ran flawless with the regular ngk. I’ve tried them in 3 different engines also and results were the same.
HONEYBADGERFTW
Houston, TX
What's the difference in BPxES and BPRxES?
NGK 7131 BPR6ES is what you're referring to, right?
---------- Post added at 01:26 PM ---------- Previous post was at 01:15 PM ----------
Nevermind, found it:
From NGK
Q: When should I use a resistor spark plug?
A: NGK "R" or resistor spark plugs use a 5k ohm ceramic resistor in the spark plug to suppress ignition noise generated during sparking.
NGK strongly recommends using resistor spark plugs in any vehicle that uses on-board computer systems to monitor or control engine performance. This is because resistor spark plugs reduce electromagnetic interference with on-board electronics.
They are also recommended on any vehicle that has other on-board electronic systems such as engine-management computers, two-way radios, GPS systems, depth finders or whenever recommended by the manufacturer.
65ShelbyClone
SoCal
"B" means it has a 14mm thread with a 13/16" hex.
"P" means it has a projected tip.
"R" indicates a resistor if present. No "R" - no resistor.
"6" is the heat range. Higher number = colder plug. Heat range span is 2-12.
"E" represents 19mm (3/4") thread reach.
"S" is for copper core construction.
You don't have to use a resistor plug, but they are easier to find and won't cost any performance. Non-resistor plugs are more useful with very high power racing ignitions that push a lot of current through the plug.
