You don't need gravity for penetrating oil to work is magic. The phenomenon known as capillary action will do the trick.
Yeah, you do need gravity. Instead of any excess fluid dripping off the nut and axle threads (if horizontal) as soon as it is sprayed on, it'll pool on the end of the nut (if axle is vertical) and eventually work its way down
by the aforementioned capillary action and by gravity and so forth. It will soak in. Keeps you from wasting this expensive product. Pretty pricey per 12 oz. can, ya knows.
In case you haven't thought about it I'll mention that with the bolts removed from the wheels only a small amount of air pressure is required to make them quite dangerous.
What do you mean by dangerous because of air pressure? The wheels are completely deflated so I don't see how they could have any pressure to make them dangerous. Unless you're talking about using air pressure with an impact wrench... sorry I just don't understand
I don't understand this either.
The nut splitters that I have seen online wouldn't fit into the rim from what I can tell. Since the bolt is deep inside the rim the splitter would be working at an angle. I'm not sure if that would still work.
You are correct. A nut splitter won't fit in the recess. Good call.
...The wheel is also held on by a keyway block thing and it seemed just as tough as the wheels. Any idea on how to get that out?
The keyway is the slot. The locking part is the key. A piece of 1/4" x 1/4" keystock is what's usually used. It's just square steel rod that is cut to desired length (e.g. made into keys) for axles and other shafts.
One you get the axle nut off
and the wheel too dadgummit, the key might have welded itself in place by a process called 'galvanic corrosion' because of the two dissimilar metals--steel and aluminum. Again, penetrating fluid, heat and physical force are your friends here. I would tap it out of the keyway with a ball peen hammer and a hardened steel punch, about 3/16" diameter or such.
'Bout time to just take it to your local auto mechanic/grease monkey/shadetree mechanic and have him air-impact-wrench the nut off. There's no dishonor in falling in battle before a superior foe.
Good deal, good deal. This is progress even though it may not feel like it.
