anyone got any guides
hondagx160
hi i am starting a project and i just wanted to know if anyone has any guides or anthing of the sort
Thanks
-kyle
freakboy
the names 'mater
hick town
Design a frame and then figure out what engine clutch and axle set up your going to use. What kinda gokart do you want on road or off road?
freakboy
the names 'mater
hick town
Ok well you are going to want it lower to the ground probaly with a wider wheel base so it can corner and if you can fork out the cash for it a differential.
freakboy
the names 'mater
hick town
Probaly 1" round tubing or mabey 1"box tubing. box would be easier if you are going with a basic square frame. and a 1/8th inch sheet steel for the floor pan.
Pellethuntr2
Machinist
NY
You might want to get a motor first and then build around it that way you know you're motor will work once you have built something.
freakboy
the names 'mater
hick town
that would be a good idea to do that and if you want me to i can draw you up a quick sketch of a frame designe for you. I have nothing better to do next week when im in shop.
88s10Durango
Chilliwack BC Canada
Alot of planning goes a long way to the final build , I would decide on what you want out of the kart , then decide on what engine that will give you the needed requirements for power & speed , what type of clutch setup , your final drive ratio , brakes , sit down on the floor as if you were in the kart , measure from your back to about 6"`s in front of your feet , measure how wide you are on the floor for width , add a few inch`s on each side to that , that will give you a good starting point to designing a frame to fit you , then you`d have to add in how much frame is the engine going to need , are you going to use a live axle or single drive wheel ..
A easy way to get a good idea of a frame is to do alot of searching on the net or the forum and look at other karts to get ideas , find one that you like and go from there , a budjet is allways a limiting factor in how far your project will go , good luck with your build , Bill
