anyone feel like explaining this to me?
kendelrk
redneck engineer
westland michigan
i was thinking that myself, but whats totally convincing me is A. when he pulled out the muffler it did get louder and B. when he put in the silencer it went silent, and it follows the video, i dont think you could have that same sync in video
anderkart
Surprise Arizona USA
Notice him reaching around behind the engine to choke it when he first starts it up? He's cleverly modded the engine for this demonstration.
I'll bet Its got:
The stock intake manifold port plugged off, and a second functional carb hidden around back.
The stock spark plug hole is also plugged off, and he's drilled/tapped a second spark plug in the back that you just cant see.
He's also drilled a hole into the exhaust port so it'll still run when he capped off the stock exhaust port.
Very clever, notice that rope so people cant walk around behind the engine and see it...
Bluethunder3320
i never knew carbs unscrewed like that.... lol
EDIT: ander is right. i saw him reach behind to the other carb.
r97
Measure twice cut once
Massachusetts, USA
:iagree: with anderkart 100%, exactly what i was thinking. you can see him pull the wire off the spark plug in the back to kill it too. I bet he has got a low profile manifold blended into the side of the block, or a manifold going through the shroud.
Maybe i will go leave a comment on that vid..... on the other hand it might be fun to see what people guess. so far it think Chuck Norris is the closest they have gotten! :roflol:
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Chevypower265 has it right:
So many of you are wrong, its running on gas like normal, what it is, the Engine has had lots of machine work done to it, the plug is hidden under the engine tin, the old coil wire in now the kill wire, the heads sealed off where the old plug used to be, the old intake is now sealed and there is a carb at the back of it (Watch him adjust the choke when he starts it)
Aww, crap. I was just looking on EvilBay, trying to buy one'a these Magic Engines that don't require fuel, spark, or compression to run. Think of the money you'd save! Now I'm disappointed. I was even hoping they didn't need lube, too!
devino246
Lynchburg, VA
Not only do they not need all that stuff, they dont even need to be cast or machined! Just dump some scrap in a bucket, run it over with a freight train, and WHAMO, you got a magic engine.
