There are plenty other articles regarding the company..
short story:
POEM built the karts for malaysain rental tracks..
and from the revenues start to finance their electric vehicle production..
which failed, they then got the national powercompany on board for help and still failed to get production up and running they then decided to buy in off the shelf parts instead of making them..
and it was essentially too late.. and if I understand it correctly, they're now no longer active (as frazer nash is nothing more than a dead website nowadays really)
BTW proper crimps (industrial not hobby) are done from four sides, not two.
look at the C and D connectors (microswitch potbox), those look to be crimped correctly
as are the waterproofed ones on the switch(O and P - I suspect).
Anyways
back to topic ..
have you checked the potbox microswitch yet?
if not, please do.. it needs to be connected in a NC (normally closed) setup, since you have a three terminal switch I suspect it to have both the NO and the NC terminal
it's counter intuitive since the potbox lever activates the switch when in rest...
So no continuity when the lever is in rest, and continuity when the lever is throttle is activated, still means normally closed.
remove the spade connectors and test for continuity of the switch in both throttle positions.
verify it working and we have another checkmark.
(reconnect)
Next: remove the green and yellow from the controller and test for resistance
if you can test before the potbox value is changed by the trimpot.
slowly increasing /decreasing throttle at least four cycles..
observe for hiccups in the change of resistance, and if there are none (no sudden jumps, no dead spots etc)
note down the min and max value.
and now measure the resistance of the trimpot as it sits (green lead both ends)
just note it down for now.
and yet another checkmark will be set.
Sorry, I forgot? the precharge resistor was checked, right?
The fuse and switch are okay as well IIRC..
what about the large battery disconnect, is that acting as it should?
if so I think the inside of that mystery box is now fully checked and confirmed to be working.
Which I'm afraid leaves us with not too many options, does it?
ideally incorrect trimpot settings and or potbox misvalues
What are these? and how does it change (0-5kOhms or 5k to 0 Ohms when throttle is applied)
And yes, continuity and resistance, do not check voltages!
(in fact it's best to leave the battery disconnected when ever you test some static value,
that way even if you accidentally short something with the testlead you have a much better chance of not frying the controller
Have you conducted the potbox test from earlier (post #24) already?
that I'm afraid needs to be done under battery voltage of course
(otherwise there's little chance the controller triggers the boot up sequence
but make sure the rear is jacked up, since the wheels will spin in best case
And if I just assume that too has been done..
there is very little left that could cause the setup not working
a) the motors are shot
b) the controller is toast
c) the wiring is incorrect
Easiest to test at that point are the motors.
disconnect the motor and battery wiring from the controller (take notes what goes where)
Oh and they
must be wired differently since I assume them to be identical and thus one must rotate clockwise the other one counterclockwise in order to not turn the kart in circles
now concentrate on the left motor first
Now prepare to get hit, then touch the motor wires to the battery terminal (I suggest you only test with 36V say the left batpack, just to lessen the jerk.
does it turn?
repeat with the right side motor.. and?
Where are we at?
