Any pro welder$?
JMINDY
Indianapolis, IN
My now 12 year old son, tried mig for the first time, 2 summers ago. He laid down 2 great beads, then got a "jumper" into his glove.... Last time he tried it...... :mad:
LOL, my son got one of those jumpers to land on top of his head, just far enough back that the helmet didn't cover... I still tease him of his "bald" spot!:lolgoku:
The worse is having one land between the toes... It's been said, Chopp'n Tops in Flipflops is not advised!:lolgoku:
machinist@large
West Michigan, 49331
For anyone who is trying to start out learning to weld with an AC buzz box stick welder, keep your rod diameter small, like in the 1/16" range, and your scrap metal practice plates in the 1/8" range,and invest in an angle grinder.
While I totally agree with the others that the better welding equipment brand's are (usually) money well spent, the cheap stuff from Harbor Freight will get you started. Just be fully aware that this stuff is not perfect.
Now; there's a low level debate going on about the quality of HF's welding rods and flux core/mig wire. I've never used any of it. I work in heavy industry, and buy my supplies from the same sources as the companies I(v'ed) worked for. The general consensus seems to be to shop at the US construction big box store's if you don't have access to a welding supply house for wire and welding rod.
Now; you've got the welder. Do you have an angle grinder? If you are here, then budget mode is most likely your style. I don't take the high end stuff to work any more; instead, I sampled several models from several discount sources, looking for a 4 1/2" angle grinder that at least just plain worked.
The model that seems to be the best bang for the buck that I've found so far is HF'S Chicago Electric model #91223. I bought one as a throw away over 10 years ago, and under light to medium use it lasted for 9 of them, until it was ceremoniously killed by a now former coworker.
While between jobs last summer, I picked up a temp gig welding frames for custom machines. Having to fight over the ONE 4 1/2" angle grinder the shop owned basically had me declaring that that was :censored:.
On the way home, I hit HF. I just hit their site: still listed for $21.99 on sale. Back then, I bought three of them. Set like this: one with a grinding wheel, one with a sanding flap wheel, one with a cut off disk. In use, if they start to bog down, back off.You're trading time for lack of cash. Respect them for what they are and they'll give you great service.
Now, why do you need one? An angle grinder I mean.
For any type of welding, you need clean metal. That's even more important when you are starting out: with time and practice comes experience. Without that time, practice, and experience, you need all the help you can get. That's where the grinder comes in. Trying to clean up a piece of metal using a cordless drill and a wire wheel doesn't work.
It's going on 3 AM my time: I apologize in advance if I didn't make clear sense....:surrender:
d340b
MAL brought up a very important point. Its GOT to be clean. While experienced weldrrs can weld junk its always best to have clean metal.
And you'll always have less trouble with sticking when using a quality welder.
Poboy kartman
Senior Moments Member
White Settlement Texas
I agree with the HF angle grinders.....I own several and they have held up well and I used them pretty hard. ......
I bought one from Northern Tool and it blew up in a day.......
thaipham25
texas
What part of Texas are you from? If you live close to one of us, you could probably get that exhaust welded up for free and get a hands on welding lesson at the same time..... That's why I have 3 hoods. 1 auto dark for me with adjustable shade, and 2 regular hoods with #9 &#10 shaded lenses, for anyone who wants to watch or try. My now 12 year old son, tried mig for the first time, 2 summers ago. He laid down 2 great beads, then got a "jumper" into his glove.... Last time he tried it...... :mad:
It very nice of you for the invite. Its great to know there are still people who are good hearted people out there in this world. I'm from rockport tx 30mins from corpus christi. I have to refuse bc my friend is teaching me here at home but thankyou so much.
Sent from my LGL35G using Tapatalk 2
thaipham25
texas
I started some welds so far on some scrap metal and dam its hard seeing through the dark helmet but i got it down. The heat wasn't hot enough and the ground needed to be more grounded. Had to sand off some of the paint first, that was why it didn't get hot. We also went with smaller rods since it is a small machine.
thaipham25
texas
I really believe china is getting better at making their products. The quality of most of their electronics that i own still works from couple of years ago and i used these products daily. Hf is one of my now favorite places to shop bc of the economy. Even my kart engine vegas cart 460 is a gx390 clone engine made in China.
firemanjim
Just kartin' around....
Houston Texas
That's funny..... My parents live in Ingleside on the Bay....... Right around the corner..... I go fishing in Rockport when I go visit.....
Kind hearted people? That's just Texas hospitality...... :thumbsup:
(on a side note to the mods..... I feel as if we need a cowboy hat smiley, tip of the hat smiley emoticons, since there are SOOO many Texans here. NOT to mention that it's home to our forum founding fathers...... Jut sayin..... ;):smartass: )
EDIT and throw in a "g'day" for the aussies....... LoL
thaipham25
texas
Got the mid weld in but the mufflers alumnium. ****! Melted a chuck off of it.
thaipham25
texas
Any ideas how to keep muffler on. Clamps won't work bolt will block airway
Scout
Nutjob
Indiana
Use good rods too. While you are HF buy a rod holder, they are sealed and keep out the humidity.
KartFab
Dallas, TX
At least your learned that you cant weld steel to aluminum? Always gotta check with a magnet if its shiny and feels ight.
