Any opinions?
trevmust
Calgary Alberta
What do you guys think of this frame? I think its kinda boxy, but I'm a tall guy so fancy curves wont work well lol
trevmust
Calgary Alberta
Somewhat how I want it. The battery is gunna go behind the seat and maybe an external fuel tank as well, of course they will be shielded...
trevmust
Calgary Alberta
I'll be a racing seat. I just needed something to kinda plan out how long it is. the steering shaft is too short i think. I will probably put a slider bracket under the seat. not sure yet.
trevmust
Calgary Alberta
the seat frame there will likely be tubular while the rest is square stock. but I'm not sure how I can attach the swing arm if do that unless I do a tube frame with square stock supports if you know what i mean?
trevmust
Calgary Alberta
I need to actually get measurements before I can do anything concrete. but I am using welded on brackets and I need to figure out where i am putting the shocks
middleg
This is something I would like to do. exept maybe square up the ends and make a taller back. I would not use suspetion arms up front just spindles with springs. Would you mind if i used these ideas for my kart.
trevmust
Calgary Alberta
not at all. we can compare along the way. if they look similar in the end we can name them thing1 and thing 2!
any suggestions on how thick the walls should be on the tubing?
Let's start with some overall dimensions. Based on what we have, I'm heading towards something in the ball park of 1 1/4" or 1 1/2" 16ga
trevmust
Calgary Alberta
I'm 5'11, so the distance between the pedal and the *** of the seat should be about 3 feet or so? no tape measure to check accurately lol. near me that is
middleg
What are the chances of that I am also 5' 11". I have heard it is better to go with a bigger size of square tubing and a lighter gauge that a heavy gauge and small metal. So I think 1 1/4 16 gauge would be enough. What are you planning on doing for hooking the shock from the swing arm to the frame. I will use 13 1/4 inch shocks from northern tool.
middleg
Have you decided what you are going to use for metal I'm using 1 1/4" 16 gauge and what will you be welding with. Wire or stick?
