Another TC question
Kleyny
Brisbane Australia
I have searched for my answer but can't find it.
I have an off road go kart running a gx200 clone.
My mods are or soon to be air filter upgrade, exhaust upgrade and a modified governor to around 5000rmp.
My local supplier of the TC, thinks that a after market tav30 will chew belts with the extra hp and the sort of terrain ( softish sand and bumpy ground). He recommends I upgrad to a 10hp TC for an extra $70.
Do you think he is being over cautious or is he right?
Because I'm in Australia postage from the states can be a killer.
Anyone have links to the clone tav 40 that would be good, hopefully one of these will have decent freight costs.
Thanks
Neil
Joe-405
Enjoying New Projects
U.S.A.
I have a bsp engine with a tav30 knockoff and have not changed the belt in 3 years. I think hes looking for a upsale. The bsp or aka box stock engine makes more power and ive seen 5k+ rpms also. www.boxstockproject.com is my engine
Just make sure your gearing is right.
How big are your tires? - Diameter of tires.
How heavy is your kart?
How many teeth on the rear sprocket?
30 series should be fine.
I used to run a modded 6.5HP engine on a 300 lb+ buggy with 16" Tires and a 30 series Torque converter and 6:1 gear ratio. I wanted more low end so I switched to a 7.5:1 gear ratio and this is what I got. It was fun.
https://www.youtube.com/watch?v=xL7FUcA3o2U
Kleyny
Brisbane Australia
I can't get to the kart for a few days but from memory the rear tires are 13", rear sprocket is 50 or 48 tooth and the front is 10 tooth, the kart weighs 200lbs and I roughly weigh 205.
Thanks
Neil
---------- Post added at 04:48 PM ---------- Previous post was at 04:39 PM ----------
Nice.
Is your kart a off road or on road?
Thanks
Neil
I think that engine with a 30 series should be ok on that kart.
Do you remember what pitch chain/sprockets you are using?
For the torque converter jackshaft, try to get an 8T or 9T, 5/8" bore jackshaft sprocket that matches the pitch of the rear sprocket.
should be something like #35, #40, #41, #420,...
That will put you around 5.3 :1 to 6.0:1 gear ratio. Should be good with a TC, and 30 series.
Kleyny
Brisbane Australia
Kleyny
Brisbane Australia
Here in Australia I can only purchase TC a kit with a 10 tooth spocket.
This leaving me with a gear ratio of 5:1 running 13" tires and a kart and rider around 375lb.
Am I asking too much out of the TC?
Should I purchase a 9 tooth sprocket from the states?
I have been running 5:1 on the centrifugal clutch and unless a 224lb mate got on it the clutch handled it ok ( smoked a bit with him on it on a bumpy track).
Sorry for the questions but I dont want to burn belts out.
Thanks
Neil
Kleyny
Brisbane Australia
Well the TC turned up today.
I had a bit of a dummy fit up.
Because the motor is behind the axle it made it a little difficult.
I settled on raising the motor up to clear the tyre and give the chain a half decent angle so it clears the internal ribs in the TC mount plate.
Thanks
Neil
If the 10T burns up belts too fast, then get a smaller drive sprocket or a bigger rear sprocket. I'm guessing 5:1 with 13s and a TC will be ok.
Try it out and see. Then make adjustments. The best education is first hand experience.
Kleyny
Brisbane Australia
We shall soon see. I hoping it will be ok, I don't want to lose too much speed.
I'm hoping to have it going by next week end.
