Another project, beater bike DS80
Kaptain Krunch
Pro Junk Collector
vermont
So, spent most of my time trying to rig a clutch and throttle cable, with no luck. Fishing line is too stretchy for throttle and i dont have a long enough cable for the clutch. Anyways, i started it up, let it warm up, and after about 5 minutes of idling and adjusting the carb it died and lost spark. I have no clue why, anyone have any ideas? The points are clean, but the gap is probably a little too big since i had to take a decent amount of corrosion off, no clue if coil is ok, but it wasnt getting hot or anything.
crazycart
RedNek Engineering
MINNESOTA
Probably coil or condensor. Check the flywheel key and all connections. I had problems with the wire coming off the condensor.
Kaptain Krunch
Pro Junk Collector
vermont
I'm thinking it may be condenser, but i need to replace the points first. The piece of spring steel actually snapped while taking the points off, and it wasnt very springy anymore, so i'll replace that and see how it runs. I tested resistance on the coil and all seems well. If it is the condenser, could i just rig one up from an old kohler or something that has points?
This is starting to turn into a money pit...hope it rides good.
Cam
Nz Petrolhead
Whangarei, New Zealand
After getting a new set of points you could wire the points up to a battery ~ car coil to test if it was the coil/condenser was causing the problems.
Hows the shifter kart coming along?
Kaptain Krunch
Pro Junk Collector
vermont
I might have to do that, i really hope its not the coil. I dont feel like putting more into this bike...
The shifter kart is at a stand still also, coil is shot on that i believe. I'll be setting up the steering rack soon and get some pictures of that.
Kaptain Krunch
Pro Junk Collector
vermont
Alright so i ordered new points, installed and gapped them and she runs great. Rigged up a tank and fishing line throttle cable and rode her a bit, Shes got great power for an 80 enduro. The fishing line is too stretchy so i need to find something better, but other than that im pretty psyched. heres a vid, filmer sucks, sorry.
http://s523.photobucket.com/albums/w355/houdinky/?action=view&current=DS80.mp4
It wont embed the video...so just click the link.
Kaptain Krunch
Pro Junk Collector
vermont
Ok, so heres the videos. i put them on youtube. The bike is about as complete as i'll get it.
Heres the first video i took. guy who filmed it wasnt the best. This was 2nd or 3rd ride i took on her, so i was still getting used to the bike. Still not completely used to such a tiny bike... http://www.youtube.com/watch?v=pw6ZRCj0VxQ
Heres a quick walkaround the next day after i JB welded the gas tank up real good, and set up clutch, and throttle linkage. Home made gas cap is shown in there too...basically a bolt welded to a piece of steel rod, a nut, and an old motor mount from a golf kart. http://www.youtube.com/watch?v=-RGXbPidj2g
Kaptain Krunch
Pro Junk Collector
vermont
so, a little update on the beast. I've been trailriding 3 or 4 times, first was a 7 hour long ride and i had no trouble at all, ran great the whole time, second time i took a break and it wouldnt start back up (i think the float stuck open and flooded it), but it started up the next day. Third ride i got a flat, no surprise since the tube had 3 or 4 patches already, i road it home on the rim, prolly 10 miles. Tire was already shot anyways so i need a new tire and tube.
But other than those two little things shes taken the abuse great, and it is some serious abuse, i'm talkin rocky trails up huge hills, lots of wide open, i cant tell you how many times i've had it completely topped out in 5th tryin to keep up with a CR125. She has decent power, i think if i did a top end it would help, but im not gonna. Probably tops at about 50, but its very steady, and pulls pretty good.
So thats about it for this thing, i also re-painted it flat black and red. I'll get some pictures once its back at my house.
crazycart
RedNek Engineering
MINNESOTA
You cant beat these old bikes...just sat on my KD100 today... i don't know if i can bring myself to sell it!! Its just too cool.
Kaptain Krunch
Pro Junk Collector
vermont
Yeah, unless someone gives me like $500 i aint selling this either, these old bikes are great, they really take the abuse. plus there so simple to work on, no radiators or CDI's. I'm actually thinking about gearing this thing up a little and making it road legal. She'll do about 50 as is, which is really all i need, but thats pinned so if i go up a tooth or two in the front that would fix my problem.
