justinlogue5_0
Can't leave it Stock!
Ok I just got it all back together and to me it doesn't seem like its running right BUT this is the first one I have built with a cam.
Gov removed
Billet rod
Mod II cam with 18lb springs, valve lash .003 for both
Billet flywheel(straight up key is 32*) I de-vanced it 4* to a 28*
Coil gap at .030 per instructions.
Changed from tank gas, to a pulse pump with the adapter that goes behind the carb.
Air filter
Header
Emulsion tube with larger jet(can't remember actual jet size)
No oil sensor also
Now the maybe issue. As I started cranking it, it would hit and instantly die. Had to give it gas to get it to stay running. Kept it running kind of fast with some good revs and then let it die to check for leaks,bolts still tight etc.
Cranked it again and this time second pull it fired right up and is staying running but it surges up and down nonstop. I sprayed some oil around the carb thinking maybe I was sucking air and it didn't help. Should I put the timing back to straight up 32*? Or???
If this works, here are some videos of it.
Gov removed
Billet rod
Air filter
Header
No oil sensor also
