freakincage
Hello Gurus,
It's been a while since I've had to post a question because I can usually find it by searching...but this has me kinda stumped.
Some of you may know that in the fall I picked up a beat up Sears Roper to revive. It was missing many parts, including the factory jackshaft, so I have to fab one up. I'm now at the point of putting the drivetrain into it and I have a couple of jackshaft questions.
The previous owner had the chain going directly from the clutch to the rear wheel and as a result the rear wheel had to be off center to get everything to line up. I want the rear wheel centered in the frame, so I need the jackshaft.
The power plant is an ungoverned Briggs 5hp. No other mods, just no governor.
I have a 12T clutch for the engine and a 60T sprocket on the rear wheel (5:1 ratio).
Locally, the smallest sprockets I can get to for the jackshaft are 16T.
I was thinking of this set up:
12" diameter wheels
12T clutch to 16T input on jackshaft (1:1.333 ratio)
16T output on jackshaft to 60T rear sprocket (1:3.75 ratio)
Based on what I've read to calculate this, the final ratios works out to be 4.999:1 (1.333*3.75), resulting in a top speed of around 25MPH and decent enough torque to get going.
I've also read that it is the final gear ratio is all that matters, but that doesn't really make sense to me because of the variables added with the jackshaft.
What are some thoughts on my proposed gearing (aside from "try it and see")?
Thanks in advance,
G
12" diameter wheels
Thanks in advance,
G
