anickode
Snagged another free engine (well, a generator) a couple weeks ago. A coworker asked me to take a look at it. The engine ran fine but it wouldn't make power. He said if it can be repaired for less than 20 bucks (which is frequently the case if it's just a bad exciter capacitor or brushes), he'd pay me to fix it, otherwise I can just keep it.
Well the generator looked like it fell in the ocean, both outside and inside the gen head, and the exciter winding failed a megohm test miserably.
I figured out a trick for removing stubborn armatures from a tapered shaft. Simply thread a grease zerk into the end of the armature where the long retainer bolt would usually pass through, pump grease into it till you can't pump anymore, and give it a light tap with a hammer. Popped right off. No pullers, or pushers, or stacking bolt shanks up in there and cranking down.
Anywho... It's a good solid running Briggs 10hp OHV. She ain't pretty, but she starts on the first pull, doesn't leak oil or blow smoke, and has good compression. Its the tapered shaft, but fortunately it's the kind with the long straight 7/8" shaft section before the taper. Will be an easy conversion. No clue what I'll use it for, but one can never have too many good engines laying around, IMO.
Another quick note... Most portable Coleman/powermate style generators that did not come equipped with auto-idle do not have an idle jet in the carburetor, so they usually won't idle without the choke on. A different carburetor is about the only good way to rectify this.
Couple quick pics... The long shaft with the tapered end. Much easier to deal with than the tapered stub-shafts that you'll frequently see.
And the end of the armature, where I tapped some 1/8" NPT threads (didn't even have to ream it to size first), and installed a grease zerk. 10,000 psi of pressure (typical for a grease gun) and one light tap with a 16oz hammer is all it took to get the armature off.
