Mybreathyourlung
- Messages
- 5
- Reaction score
- 0
I picked up a kart that someone else started. All I’ve done thus far is plop an engine on it, add a clutch and sprocket and tried to get this thing moving.
Imgur album of kart - https://imgur.com/a/IaWM33B
Engine - 6hp Mitsubishi GT600, I believe 3600 rpm, the governor on the inside of the crankcase is intact and you can see in the pics how I added springs to the throttle/accelerator pedal.
http://www.wme.cn/MITSUBISHI/GT600.pdf
Sprocket - Azusa 60 Tooth 35 Chain Sprocket 4-1/2" Drum Riveted Mini-Hub, 1" Bore
https://www.amazon.com/dp/B078XQZYZY/ref=cm_sw_r_cp_api_i_dUhpDb0SR2WD1
Clutch - Homgrace Centrifugal Clutch, 12 tooth, #35 chain
Wheels are 11” diameter.
The engine runs great. When revving the engine high and the back wheels jacked off the ground the clutch engages and turns the wheels freely, picking up good rpms. The issue is when the kart is on the ground and the same as above is done, the kart doesn’t budge. The inner part of the clutch spins and I assume it’s trying to engage the outer but doesn’t. I don’t hear any odd sounds and nothing smokes. I’m at a loss. Thanks everyone.
