parts in, and modded
so it is shorter than i thought it would be, but more than enough for a good hose clamp on each end. i will be using 1" heater hose to couple the items. right now, it is 2' long so i can fine tune the length (i have a spare 2' piece). what fun that will be!! (rolls eyes) anyway the pic of the head is my 160 head, that i was porting and decided to see about messing with the chamber to see if i could get some gains there. by channeling the gases to the exhaust valve on the up stroke, i hope to see some gains. in seeing some of you guy's porting pics, i was wondering why you grind down the valve guides. i am ramping mine into the valve. course with out knowing the valves deployment, i can only guess at which angle i should put. why am i doing this? the bore for the valve is flat behind the guide, by ramping i hope to cause the still air/fuel back there to surge into the chamber quicker. because i haven't decided to run jb or other epoxy back there yet. i know you can't tell easily in the pics, but i did align the intake sections to their corresponding parts.
