moose
There called cable sleeves pal. I gonna use them but I don't know how I'm going to get the cable from the pedal down the chassis, and then bend it to get the throttle cable obviously the lever on the carb isn't level with the pedal......
Uhhhh.. what? You should be able to route the cable however you want. Terminology for bicycles is inner cable (shift/ brake) and housing here.
If you use a bike cable (cheap and easy), one end has a lug that you can use at the pedal end, all you need to do is put a stop for the housing somewhere before the pedal. The engine side should have provisions to hold the housing and clamp the inner cable.
If you cut the housing, be sure to trim and file the end, then put the little metal cap back on. These caps are pretty important.
Also grease the inner cable.
Hope this helps!
